current draw USB socket in car (12v)
14 Dec 2005
with a socket like this
http://img.dxcdn.com/productimages/sku_258722_4.jpg
I know current=power/volts, but how does the voltage reducer on these sockets affect the current draw from the battery to the socket?
say its a 2amp device being used, so that must be 2amps between the 5v side of the socket and the cable to the device. But what about on the 12v side of the socket to the battery? Still 2amps or does the voltage reducer increase the load?
hi...cheers
so,depending on the sockets circuit design... it would be roughly between 50 and 300w/12 + the amps drawn from the usb device?
that makes a big difference to the size of cable I thought I needed!
Arrgh.....
Try mA as the figure for the extra current draw, not watts :P
(Blame posting from the phone and not proofreading very closely)
You want reasonably chunky wire (Volt drop on 12v can get quite high), but nothing too silly.
ahhh gotcha, that seems more reasonable! (anything beyond a single resistor I don't know how to work out figures...need to do some reading) :)
I have flat twin 1mm(squared), approx 5metres cable run.....voltage drop calculator on 12v planet says 3.6% (0.43v) drop for 2.5amps....sound ok?
(Ignoring any increased load from the device used to reduce voltage)
Drawing 2amps on the 5v side will give 10watts.
To get the same power on the 12v side, you only need 0.83amps.
