GinG said:is the ninja just a fan, does it need a heatsink bought seperatley?
Joe42 said:If big typhoon is significantly cheaper it might be worth getting. It should perform quite well but i'm pretty sure they don't include a fan.
Gashman said:whatabout the thermaltake blue orb II, i have one and i find them highly under-rated, mine has faster spinning 120mm fan and it knocks 2*C off the idle temperature compaired to stock fan
Edit: 3200+ running at 2.85Ghz at 1.55V, 33*C idle with room temperature 28.5*C
Only worth getting if its a lot cheaper then.Raikiri said:It isnt quite as good but it does include a fan.
Aye just fitted the cooler in a P180 case cooling X6800 27c idle got a 1600 rpm fan on very quiet well chuffed with this coolerCS||nuTs said:Scythe Ninja IMO
Yep if you can find one :/lay-z-boy said:tuniq tower is the king of kings![]()
