- 12 Feb 2014
- Somewhere Only We Know
Ive got bored of messing around with ram now on the new bios, it just doesnt seem to be giving me anything extra out of my kit, so ive taken to playing with CO instead to try and get my temps down a little.
Im running a 7900 non X, with 64gb (2 x 32gb) G.Skill Trident Z5 CL30 6000mhz @ Buildzoids timings and 6200mhz, on an ASUS X670e Gene, ive added a +125mhz boost to the CPU, I cant go any higher as it causes all sorts of problems, ive just ran quick tests like Cinebench to verify this for now.
So now im playing with CO, at the moment all my cores are at -15, I started at -10 a few hours ago, the way im testing is with OCCT who make it easy to do per core tests (you can see it in action in the pict below), so far ive managed to shave about 10oC off the chip, if I can get all cores stable at -20 then im going to probably stop there as im not going to fight to get maybe -1 or -2 more out of some cores and -5 out of others.
I just want to clarify that im doing this right, so ive set the timer for 2 hours, this allows for 2 passes of each core, 5min testing at a time on each core, a total of 10mins on each core across the 2 hours, im using the small iterations set and im starting with SSE instruction set as this gives the highest boost, and then testing 2 hours with AXV, then again with AVX2, a total of 6 hours running, total of 30mins on each core, if theres no errors, I then goto the bios, adjust by 5 points and run all the tests again, would this be the correct way to do it ? i'll eventually finish off with an overnight test for each instruction set to make sure, ive never messed with CO before so sorry if this sounds like a stupid question, the only chip I did in the past was my 5800X3D and that was easy, unless you got a bad one, they all did -30.
