- 2 Mar 2004
- SE England
Afternoon all,
My dad's at his wits end with a Renault Alpine GTA Turbo that he's got. I believe it uses a Renix ECU, a la Jeeps of the '80s.
The symptom is that when it gets hot, it starts to hunt - and won't build any power. Eventually it'll cut out, or just continue in its hunting cycle, down to nigh-on 0 RPM then back up to 700 or so. The engine electronics warning lamp flashes during this, and occasionally will glimmer while driving.
I've not looked at the car closely myself, but I can tell you the following has been changed:
- Plugs
- Coil & module
- Leads
- Crank position sensor
- Oxygen sensor (I think)
It's also had some restorative work done to the wiring harness and ECU (dry joints).
It appears to do the same thing with the TPS unplugged, and I'm told it still does the same with other sensors unplugged - but I was wondering if anyone could give me a bit of a steer as to where to start.
It's a shame, because otherwise it runs fine when cold and drives very sweetly indeed. That, in my mind, voids any problems with the fuel side of things. Might be wrong, though.
Any pointers, so I can jump in better armed? Appreciate it's not exactly a common car, but it's not entirely different from a lot of modern kit - nothing ventured, nothing gained!
Half wondering whether I can get it to run in open loop all the time, like it's cold - might stop it doing it...
Cheers! Any guidance appreciated.
- Plugs
- Coil & module
- Leads
