Custiom Ringtones on iPhone?
16 Oct 2005
Poole
Hey guys just wandering if you know how I can create custom ringtones on the iPhone? Searched online and all the methods seem outdated as most use iTunes to do it :(
Thanks.
All good until I sync my phone and it still doesn't show up in "Sounds" in the settings menu :confused:
I've just upgraded to the 5.0 beta and so had to reinstall my ringtone (one that I created from that site).
I searched for it (using the google search bar at the top), selected the tone, downloaded the iPhone version, double clicked it (it starts playing), I sync my phone and then select it under the sounds menu.
Worked perfectly - Not sure why it wouldn't for you.
