Hi all! I already posted this but maybe I put it in the wrong area.
Anyone know where I can get a custom backplate made in the UK or any backplate that fits the EVGA 570 HD 2560. I asked EVGA and EK and they dont do them..
I checked on there, they do a 570 and 570ti backplate but not one for the 570 HD. As far as I know they are slightly different. I cant find anything else so I have just ordered the standard 570 one. I don't want it for thermals, just purely cosmetic so if it doesn't screw on I will just do the Velcro trick. Cheers buddy.
oh wow, I never heard of them. That's exactly the sort of thing I was looking for. Didn't have to be only UK but didn't want to be shipping from the US.. EU is ok!
Those are really nice. Hmm I already ordered the EVGA one now, Oh well there's always ebay!
Hi, the backplate from the normal 570 will not fit the HD card because this is shorter then the normal card. Most customer that wanted a backplate on the HD model modified the 560 TI Backplate like in the following link to fit on the HD card. http://www.evga.com/forums/tm.aspx?m=1271736&mpage=2 Did you order the backplate directly from us and do you want to cancel this order?
I really like it! For some reason Lian Li stopped doing them. They were £300 but I found a B-Stock one with the secondary hard drive chassis missing for £120! I didnt even need the chassis cos I used that area for the rad, result!
Can you send me your order ID or the email address of the account to [email protected] then I will try to stop the shipment. In case it is too late already or it is not possible to stop it you can also just decline the delivery...
