Custom Build PC £1200 Budget
10 Oct 2014
Hey, so I am finally at the time were I need to buy a new rig for gaming. I am after a system that can get a at least 60-100FPS if possible. Games I intend to play with the new system are,
WoW - Shadowlands
Assassins Creed Valhalla
DOOM Eternal
RDR2 (Red Dead)
I have approximatly £950 to spend on the system if that helps.
So I have had a little look, and I am planning on increasing my budget to about £1200 and have come up with the following items for the build. Would any one be able suggest any improvements or to save on cost?
  • MSI MAG B550 Mortar
  • AMD Ryzen 5 3600XT
  • Patriot Viper Steel 16GB @ 3600MHz
  • WD Blue SN550 1TB M.2
  • Kolink Modular Power 700Watt
  • Zalman K1 Rev A-RBG Case
  • GPU (Not decided which to go for yet as I wanted a 2060 Super)
Thanks in advance for any help/suggestions that you all may have.
Hi
You might find the R5 3600 for less money.
Swap out that psu for something better. A Corsair TXM 650W for example.
Everything else looks ok.
