- 17 Apr 2016
Hi Overclockers forum i am new here i just want a little advice please, so i am about to start my very first custom sleeved cables, just a few thing i need to know correct me if i am wrong please.
So for the female pins they go to the motherboard 24pin for example
and the male pins connect to the 24pin? its for extension cables
also would you guys recommend 450 or 550 paracord and what other sleeving would you recommend as i am going to doing all diffrent cables to see what i like best i am not going to be adding them to any of my systems until i know i have got the cables down to a T
Thank you for you time.
- Kieran.
- Kieran.
As an alternative there are already made sleeved cables, but some of them would fit directly, like SATA cables, and some of them would be just an extension, like mentioned 24-pin cable:
