5 Jun 2021 at 19:50 #1 Reppyboyo Reppyboyo Soldato Joined 3 May 2004 Posts 3,309 Hi, Which are the good sites to get custom length PSU cables for a SF600 Platinum? I know of CableMods but thats about it, are there any alternatives? Thank you for your time!
7 Jun 2021 at 22:44 #2 Cooler running Cooler running Associate Joined 28 Mar 2019 Posts 1,117 Location Channel Islands I'd probably go for an extension kit such as: https://www.overclockers.co.uk/bitfenix-alchemy-2.0-cable-extension-kit-black-cm-35c-bx.html OR if you're feeling adventurous https://www.overclockers.co.uk/lian-li-strimer-rgb-24-pin-motherboard-cable-cm-017-ll.html https://www.overclockers.co.uk/lian-li-strimer-8-pin-rgb-pcie-vga-power-cable-cm-018-ll.html Fully functional replacement modular cables tend to be a risky buy, as there isn't much standardization on the end which connects to the PSU.
