Custom cables?
9 Jan 2010
Norfolk
I'm on the hunt for some better sata power cables. Ones that put the power leads straight into the back of the connector rather than passing through the back of it in a chain. In my new htpc the drives sit so close to the bottom of the case the sata plug wont go in. Can't bend the power cables enough.
I've found the phobia multi sata power 4x online. Sadly ocuk don't stock it. But that is the kind of thing I am after.
So question, what brand do you guys buy? Or do you all make your own?
