Custom cables
23 Aug 2010
Howdy hive mind,
I have a 650w EGVA SFX power supply, and am about to take delivery of the coolermaster NR200P (when stocks get released from OC). Given where the PSU gets situated in that case, there will be a lot of wasted cable that I just don't need, so I am interested in getting a shorter set.
I have googled around for custom cables, and they seem very expensive. Also, getting EVGA compatible ones seems quite hard. Apparently they use a different pin-out from corsair and silverstone.
Does anyone have a good source for custom cables?
Howdy hive mind,
Best place in UK is Pexon PCs. I believe OCUK use him for their special builds. I have used him over the years and have had PSU custom length/colour made. Google him and see if it works for you.
I've seen plenty of services available on Aliexpress. Has anyone tried them before? Obviously longer lead time, but might be much cheaper.
