- 15 Feb 2011
Just wanted something a bit different. Open fronted but with a short depth (30cm), as it's resting on my desktop.
Inspired by the Lian Li PC-A17A.
The MB tray came from a Compaq Deskpro EN. It didn't fit in it's original form. No problem for the angle grinder though...
Case is MDF (cut with a flat bed rip saw), covered with earthed aluminium foil on the inside for EMI protection.
The rear has a 3U perf plate leaving 1u for cable exit (front is 4u).
BluRay Writer is external. The BluRay case was modded to accept a 4Pin locking socket as the mini-din connector was flaky. Powered by the computer PSU from a molex connector on the chassis.
Quad core AMD with Munchkin memory running XP.
