Custom cooling for a GA-x58a-UD3R NB
16 Dec 2010
I own a OCUK ultima dreadnought. It has the GA-x58a-UD3R rev 2 mb.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-235-GI
I have been having problems with the northbridge overheating, on the stock bios (ver. FA) when the NB gets to a cirtain temp, the bios 'limits' it to protect it and bring the temprature down. This causes major dpc latency spikes for the duration and causes audio to stutter and pop and fps games become unplayable.
The latest bios ver FE, fixes this NB limiting and solves the important performance issues, I am about to upgrade the bios now (although concerned that ocuk will refuse to support my system after a bios upgrade).
However I am now worried about the Northbridge actually getting to dangerously high tempratures.
Because the cpu is watercooled, there isn't any of this extra air flow near the NB as you would get from the stock intel cooler. The system is of course preconfigured overclocked one so I was wondering if I could get some more cooling on the NB somehow. It is too hot to keep my finger on it after the system has been on (and this is without the FE bios that probably will allow the NB to get hotter).
I was wondering if a small fan like:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-030-AK
would work, but I have no idea how to attach it, I have never done something like this before (although it probably is simple, I am noob doing little additions like this).
You can see the NB heatsink on thats on there in the top link picture.
Since this overheating issue has so far crippled the system as a gaming rig, which is what I bought it for, should i contact OCUK customer service or something and try to negotiate a solution (maybe send me those fans for free or something) or is that too cheeky even though I payed over £1300 for this system!
I am also worried about doing a bios upgrade and ocuk say that because i changed it my oc is not supported anymore even though after doing extensive research this bios upgrade is the only definate solution to the peformance issues.
Thanks for any advice,
Mark.
so would that be mounted by hooking it under one of the mobo mount screws then the fan on top is angled towards northbridge to blow air onto it?
How would I go about mounting a simpler fan directly onto the nb heatsink?
Should a fan on the heatsink should blow air onto the heatsink or away from it for optimum cooling?
I know I must seem totally noob (but I am when it comes to fans and cooling :p )
How can I attach a fan to the NB like in these pictures?
Are the fans screwed on or attached some other way?
What direction are the fans blowing?
Whats the pros/cons between the two fans in these pics?
Also it was mentioned that the blue plate with 'gigabyte' written on it was removed. Is this because it can be cooled better without it? I guess this plate isn't actually the heatsink and its just on top of it? (why?)
The forum I found the pics on is here http://www.overclock.net/intel-motherboards/909085-ga-x58a-ud3r-northbridge-cooling.html
(p.s. how to I resize large images down in forum posts?)
