Custom CPU watercooling help
I've been reading and apparently the RS360/RS240 is good enough for a CPU only loop. GPU cooling is out of the question so is there really a need for giant radiators and powerful pumps?
Also do these kits have a life of 1 year only?
they should last for a few years
Those reviews will most likely be talking about older CPU's?
A 3930K is pretty hot, especially when overclocked. A decent 240 will cope, the RS isn't really decent. it's borderline
"RX360 > RS360 > RX240 > RS240"
So the RS360 is a good option or is the pump to slow for the hot 3930k's. Sorry for so many questions.
That's fine :)
EK Supreme HF is not as good bang for buck as the XSPC Raystorm. It performs slightly better and is less restrictive and costs less! so win win ;)
http://martinsliquidlab.org/2011/09/26/i7-2600k-cpu-xspc-raystorm/
http://www.overclockers.co.uk/showproduct.php?prodid=WC-069-XS
of course IF the OP decides to go fully custom ;)
EK's new jet plates bring it closer to the raystroma nd it can also fit other sockets :D
