Custom dust filters
10 Oct 2006
N.I.
As of late i'm getting loads of dust in my case, mostly due to building work next door. Need to dust proof my PC.
Case is Antec900 with all fans on low, need custom cut piece of foam for two front fans, which is apprx 300x160mm, and side panel for 120mm fan (no fan, cant fit it due to huge cpu tower cooler). I'll make the frame myself, but where do i get non-precut piece of filter foam for this? Quarter of a square metre would be good (500x500mm)...
I only find small pieces suitable for individual fans. Cant be bothered disassembling whole machine just to get to the front fans.
OC doesnt seem to sell filter foam, only silencing kits...
Also, how are they rated in terms of airflow ? What sort of foam (or other materials) should i be looking for ?
Any advice on this is welcome.
Thanks...
They're fantastic. Catch all the dust and are magnetic enough to keep it in place. When you want to clean it, just whip it off and vacuum clean/wash under the tap.
Honestly all you peeps who always mention fat women's tights I would love to see your installations with them on. :p
+1 for Demciflex. Might be a bit expensive but it works well.
The problem with tights is actually getting applying them to the fans/bracket in a way that makes it easy to take off for cleaning/replacement. 9 times out of 10 this isn't possible and i cannot think of a way that would be suitable for an Antec 900.
