- 18 Oct 2002
- The land of milk & beans
The javascript idea isn't going to fly as it's client side and all server side operations are executed first - so your server would send the email before it read any javascript telling it not to.My current plan is to use client side (javascript) logic to read/write to an SQL server database - if an email had been send it wouldn't send an email just display the page
My suggestion would be to have a database which logs a page error every time it occurs. You could use this database to see if error X has happened on page Y before. If it hasn't - send an email, if has - don't. It would also be worth having a switch in there to say that you've fixed whatever caused the problem and if it happens again send an email - otherwise you may get the problem once, fix it and it occurs again a few months later and you'd never know.
*edit*
just noticed you mentioned you're a C++/JS programmer. Assuming the server is ASP.NET you can write in either of those languages. If it's classic ASP you can also write that in JScript.
