- 8 Mar 2015
Hi Guys
This is my first custom case build and was hoping for some advice from some experienced modders.
Below is a sketchup drawing of the side of the case. I will make the frame out of wood and as you can see the fans aren't attached to anything. Just wondering if anyone can suggest a way I can easily make a metal fan grill which will attach to the frame and fans. I will be building a separate frame to to fit within the middle fan section to bring it flush with the top and bottom, this will be covered in a filter material to hide the fans. I will likely put magnets on the back of this filter section so it can be taken on and off, which is why I was looking to make a metal fan grill as apposed to wood like everything else.
Any suggestions are appreciated! Thanks
