Custom gaming rig spec help
28 Mar 2011
Hi
Looking for a gaming rig to be be built by OC.
Looking to spend about £2k and would like water cooling and i7. can anybody help me with a good spec for this budget.
An 850W psu is overkill for an ITX build. A 550W would be enough.
Win 10 > Win 8.1
Why a Blu-Ray drive ? Most things are digital download these days.
sorry forgot to mention no need for a monitor as I already dell ultrasharp 27" ips monitor so that gives me a few quid more on the build :)
Also looking for a full on water cooled system not one of the pre filled sealed systems, I have that at the moment on my current build and although its ok I want something a bit better :)
i went 850w because i was going to sli the 980, but figured thats too costly and up to op anyways and i chose 8.1 because it was in the basket and you get the free 10 upgrade as they can revert back if they dont like windows 10(im glad i havent upgraded anyways) and i chose bluray because the op might have blurays or what big storage discs and not everyone uses digital ;).
it was just a mock up, the op can decide if they need so and so and i also didnt add no water cooling because none of the ones i saw seem to support skylake from what i could tell and i dont know anything about building them.
You can't SLI on ITX.
If you want DX12 then you will need Win 10.
ha yeah i know, i already had the 850w in the basket along with windows so was building round it, it was just an idea, op might not even want itx, i was just trying to build a small system to show options :), but no sli and no monitor can improve the system further with the money saved.
