custom helmet paint design
18 Oct 2002
Overground, underground..
I know it can be quite expensive to get a custom design painted onto a helmet.
Would a printed vinyl be a viable and cheaper option?
yep and a lot cheaper. Drexel got some custom vinyl's for his rex. They could probably do helmet ones.
Edit - Not sure how about the helmet shape wouldn't vinyl's wrinkle as its not flat.
I thought about that.
It's actually for a ski helmet and because of vents and goggle straps the area is limited to about 8x10cm
This is what I want to put on
Would the shading be a problem?
