5 Mar 2007 at 20:58 #1 squiffy squiffy Suspended Joined 17 Mar 2006 Posts 9,055 Is it possible to create custom icons? I've created 32x32 D-Link 323 What do I need to do next?
5 Mar 2007 at 20:59 #2 TriedandTested TriedandTested Soldato Joined 11 Jul 2004 Posts 16,162 Location Neptune http://www.coolutils.com/Online-Image-Converter.php
5 Mar 2007 at 21:06 #3 squiffy squiffy Suspended OP Joined 17 Mar 2006 Posts 9,055 How do you only show the icon itself, not the background? It looks like the one I posted.
5 Mar 2007 at 21:27 #4 ns400r ns400r Soldato Joined 23 Apr 2004 Posts 3,580 Location UK, Near the middle...... Make it (properly not just rename) a .gif image and use a transparent backgound.
5 Mar 2007 at 21:29 #5 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent .png or .tiff Just a quick job... Edit: For .gif's... http://builder.com.com/5100-31-5075935.html Last edited: 5 Mar 2007
5 Mar 2007 at 21:31 #6 squiffy squiffy Suspended OP Joined 17 Mar 2006 Posts 9,055 How do you do that?
5 Mar 2007 at 21:36 #7 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent Used Photoshop to cut out the white.. gif version.. Last edited: 5 Mar 2007
5 Mar 2007 at 21:39 #8 squiffy squiffy Suspended OP Joined 17 Mar 2006 Posts 9,055 thanks, are icons 32x32? (I saved that jpeg to that size)
5 Mar 2007 at 21:41 #9 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent Depends where you want the icon to go.
5 Mar 2007 at 21:46 #10 squiffy squiffy Suspended OP Joined 17 Mar 2006 Posts 9,055 WotDa said: Depends where you want the icon to go. Click to expand... Desktop short cut icon. I've used yours, with the above ico converter and it made it smaller. It's quite small compared to normal icons
5 Mar 2007 at 21:50 #11 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent squiffy said: Desktop short cut icon. I've used yours, with the above ico converter and it made it smaller. It's quite small compared to normal icons Click to expand... Half the original? 16x16? if so thats favicon size. Iirc desktop icon size is 64x64
5 Mar 2007 at 22:01 #13 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent Edit: Comparing that to my start menu icons it looks massive.
