Custom LED lighting and where to buy?
26 Aug 2009
I'm looking to get hold of a 5 LED setup on a molex connector, anyone know where to get them? See below for an example of a single LED version.
NO COMPETITORS
Yes just no cable, LED's, heat shrink, shrouding or resistors.
I'm hoping someone here does and might be kind enough to build me one, I have an MM thread up but posted here as well for exposure.
Ive not modded any yet but its only a case of cutting and re soldering.
a 5 led strip is fine for a water res though .
Are you sure it's all about cutting and soldering ? I've made my own strip consisted of 8 LEDs, so I had to put 3 resistors there (each for every sub-string of LEDs: 1 for 2LEDs and 2 for 2 subsx3LEDs), so if you cut my strip it wouldn't work at all, but if you cut in appropriate places there's a chance it would work, but one sub-string would shine brighter (like last two LEDs for example) :p It's all about wires inside and maths: how many resistors is put for which LEDs - unless you don't know it, you can't be right.
Exactly, I'm no wizz with electronics and although it might only take me a day to learn the necessary concepts it's much easier to have someone who does know and has all the parts and tools make one for me.
A nice member called Tealc in the MM has offered to make me one :)
For how much, if I may ask ? :)
My cable looks this way (7 LEDs anyway, not 8 as stated before and all of them have sanded tops):
