Current Specs;
Asus P8Z68 GEN3 Motherboard
Intel i5 2500k 3.3ghz
ASUS GTX 570 Direct CU II
16Gb Corsair Vengance DDr3 1600Mhz
Crucial 64Gb SSD SATA III
750W OCZ ZT Series PSU
Corsair H80 Watercooling
Corsair Carbide 500R Case
I am looking to replace my H80 upgrade my GPU to a 580/590 and a custom loop for it all but not sure if my case is capable of it and if not what would be the best replacements and parts to use for my goal.
If possible I am looking to revive an old case of mine, Gigabyte 3D mercury. Its a full tower case with plenty of room unlike the 500R and was thinking could I save myself money and upgrade this case. It already comes with a 120m radiator in the top with a resevoir. Only problem is the CPU block and bracket is for my old LGA775 sockter but im sure it can be replaced?
I was thinking If i drained the fluid & gave the case a good clean I could possibly fit a new CPU block and even use the built in splitters to add a new loop for my GPU but my concern is the 120m fan and pump having the power to pump the required fluid and keep the temps cool.
If it would be a struggle is it possible to add a new radiator into the loop somewhere an loop it all together? Could be more trouble than its worth so i am asking for advice here really on the best solution as the end results with the gigabyte could be excellent or it maybe it should be avoided and I should replace my 500r & h80 with a tj07 and new custom loop.
Thanks for any help or suggestions
Matt
Matt
