Hi, when the weather gets a bit warmer, l'm going give my custom loop a overhaul new tubing + coolent, rads off and properly cleaned as usualy l just brush them off and blast with air. But this time l'm going to try a different thermal paste, as l been using MX4 with good results, read a few reviews again and what members have been using and have a short list of 4 compounds with a possible 5th:??? see below-
Short List, so peeps which one shall l go for-
1- Gelid Solutions GC-Extreme Cutting Edge Thermal Compound.
2- Thermalright Chill Factor 3 Tube Thermal Paste.
3- IC Diamond 7-Carat Thermal Compound.
4- Coollaboratory Liquid Ultra Thermal Paste.
5th:???- Coollaboratory Liquid Pro Liquid Metal Thermal Paste.
My spec 17 920:4.3GHz + Sapp/Toxic 6950 running as a 6970, Black Ice Stealth 480[3x1000:rpm fans/Pull] Rad in a single loop. During the summer the CPU was at 4.2GHz and even when we had a hot spell lol Cpu temps never went over 67'c, GPU temps55'c. Can't complain as they are not the coolest of CPU's or GPU's, but over the past few months have l have tried various Bios Settings and now running Stable 24/7 at 4.3GHs.
My Bios CPU:Vc-1.33v at full load using CPU-Z->CPU:Vc-1.32v using IBT threads set at 8->10 runs Standard then 6 runs High, CPU cores never went over 62'c due to the cooler weather lol. So if l add about 15'c to the core temps using IBT->62'C+15'C=77'C it should be ok under normal usage gaming, etc. I usualy find with IBT if the OC is unstable whether ran at Standard or High it will fail within the first 3 runs, so its been over a week at 4.3GHz with no problems at all.
Thats it folks your views apprieciated,
Oldphart.
Oldphart.
