From your image the bottom bit of the R isn't actually attached. Would you just want that connected to the bit above?
There's some bits that are going to be quite flimsy with a lot of weight on very thin joins. The top curve of the C for example is only attached by a thin bit quite low down. Might be best having it backed onto something rather than on it's own.
I don't think it'd be too difficult to do yourself out of MDF, hell you could even just use a jigsaw
