Custom metal bracket fabrication?
28 Aug 2006
Hi,
I have a TV stand that holds the TV on a VESA mount 300x300. On the lowest mount, I have 2 holes just riding sightly above the TV. I would like to hang my soundbar from there, so its mounted directly above the TV.
The soundbar has wall mountings that are approx 380mm apart.
So I would need some L shaped steel brackets that will fix on to the 2 holes on the TV stand and rise just high enough to allow the soundbar to hang just above the TV, and have a single hole offset for the soundbar mount.
Are they expensive to get custom made?
I am doing something similar myself at the moment, although its for a shelf above the TV.
You could make them yourself, pretty simple job, buy a length of material and make the L shape from 2 pieces bolted together. Just a matter of drilling the holes correctly really.
If you wanted someone else to make them it shouldn't cost that much...£40-50 maybe...
I would get them laser/water cut.. I used these guys the other week http://www.laserprocess.co.uk/
