Custom Molex Power Customization Kit
20 Oct 2002
Derby
Hi All,
Does anyone know where I can get a kit to customise molex and sata power connectors? I have a cable removal tool from sunbeam but could be doing with a load of connectors (SATA Power and Molex) as well as a punchdown tool.
I know its difficult without linking to competitors but a name of a kit would be a help.
Ah no its for SATA Power connectors so I can make them up to specific lengths, frequency apart and orientation.. :) So for instance I wanted to make a cable up that had 6 x SATA Power connectors on I could make one up custom.
So you need the connectors then, you shouldn't need a punch down tool, I've always used a flat head screw driver, the cables push into the clips easy enough. I'm not sure if I can link to the sites needed mate. E22
