Custom PC Build
14 Sep 2010
Hey guys I want to put a new computer together, been rocking this pile of scrap metal for four years so its time is up! I'm looking to spend around £6-700 pounds and this is what I was thinking of. Going to be using it for general use, fair amount of gaming and some photo editing. Thoughts, opinions and improvements would be really appreciated
Mobo - Asus P7P55D-E Intel P55 (Socket 1156)
CPU - Intel Core i5 760 2.80GHz
RAM - Corsair Dominator 4GB (2x2GB) DDR3
GPU - Gigabyte GeForce GTX 460 OC 1024MB GDDR5
PSU - OCZ ModXStream Pro 600w
Memory - Samsung HD103SJ Spinpoint F3 1TB
CPU Cooler - Gelid Tranquillo CPU Cooler
Optical Drive - LG GH22LS50 OEM
Case - Antec 300 Three Hundred Ultimate Gaming Case
Couple of things I'm a bit unsure of. Obviously the cheaper the better, are there better value options available on anything (especially the PSU, don't know anything about them), and what sort of extras will I be needing in terms of cables etc? Also considering a monitor upgrade outside of this build and was looking at the Benq G2420HD 24" LCD, anyone got any feedback about it?
Cheers,
Jamie
That build is very similar to what I treated myself to a month or so ago, same processor, same motherboard. I went with slightly different RAM and ATI gfx and a CoolerMaster case as I am not a fan of the Antec 300, but the case is a very personal choice anyway.
The build has been fantastic for me and I doubt that you would have any problems with it. I had some issues installing the CPU cooler, the Gelid, but that was because I was not thinking straight when I did it, it is a nice cooler but nothing special, so if it is still out of stock when you order you should not feel bad about going for another, similar and highly rated option.
For the BenQ, I got that as well. It is a fantastic monitor for the price, but it still has its issues, there is only so much you can get for 150 pounds really. I kind of wish I had splashed out on either an IPS panel or something with a 120 refresh rate, but within my budget the BenQ gave a good product for the price.
For the cooler the BeQuiet is a solid option. The non-modular Corsair ones are also stellar as long as you do not need them to be modular, obviously.
For cables and so forth, you should be all set with what comes with that motherboard, though you may want to invest in a DVI cable should you go for the BenQ.
I've just built a similar system using the non 'E' version of the motherboard and a Coolermaster case instead.
The whole build went smoothly with no problems apart from a slightly noisy fan in the case which I'll replace at some point. Excellent performance and so far has been very stable, though it's early days yet.
Cheers,
Jamie
As already stated above fairly solid build. I have heard a lot of good things about the BenQ monitors. The akasa cooler is a decent one and should meet your needs as I currently have the stock i5 760 intel fan with an overclock to 3.2ghz so it should suit your needs well.
Do you need OS?
Cable wise I think you should be ok unless you get the BenQ then i suggest getting a DVI cable unless supplied.
im no overclocker but from wot ive read about the forums, overclocking with stock cooler is a big nono. kinda playing russian roulette with a full clip:confused:
watch urself.
As long as his temps are fine it won't be a problem. Doubt he even had to change the voltage for 3.2 as I barely did for 3.6ghz
3.2 even on stock is quite safe. 0.4 overclock, wont need to up the voltage and the temps will not be that much hotter anyway, the only problem is intel stock coolers are noisy as anything and will be even more with any overclock. wouldnt go much over that overclock with it though. Wouldnt be too confident of overly long gaming sessions but if its stress tested etc and the temps are ok then its all good - got nice cooling case aswell.
I was originally planning to the the stock cooler, but ordered a different one at the last minute. When the CPU arrived I was very surprised by how small the stock cooler is. It doesn't look up to the task at all. I'm glad I bought a larger one.
I don't game for overly long sessions and i'm not pushing it any more as it stands, looking into new cooler now as well anyways. Temps are only a few degrees different anyways, voltage is same as stock.
Hey its your machine. If its been stress tested n checked then you know how much it can do. Didnt think it would push the temps up much because its quite a moderate overclock. Question though: is the cpu fan any noisier? I imagine its running faster than stock and have only heard bad things about its noise levels but its a very adequate cooler. A new cooler will give you 2 benefits: 1) will give you more room to play around and overclock and 2) it will look sooo much better xD
I know it will be the next stage in my pc upgrade. Erm its not really any noisier really to be honest and I use music with speakers most of the time. Or when gaming i use a headset so its not noticable over even low level music or iplayer etc.
Of course the intel fans do look pretty dull to be fair so something new and shiny will make it look much better too!! :)
Cheers,
Jamie
Good spec there, I went with the same motherboard and CPU combo and they work very nicely. The G-skill ram is worth a look as another alternative.
