Custom PC Desk
1 Feb 2010
My efforts to find a red harbinger cross desk have failed and so I'm now committing myself to a crazy task to design one myself.
Having spoken to a metal smith and confirming it is possible to get them to create my design I've started with Google SketchUp
I will post sketchs as I go along
First design attempt
[/url][/IMG]
What material and the reasoning for it, are you intending to use for the desk pls dude?
I'm wanting to start a custom desk project myself but it's going to be a larger corner desk type
Materials
I plan to make this desk out of metal, I've spoken to a metal smith and he says its doable, this may change depending on what he says when he sees my designs, the front see through piece hopefully will be some sort of glass/plexi and will be a custom water reservoir, I'm using metal due to its fantastic ability to stay cold and that it looks very sleek in black.
Failing the metal route if im to go down the wood route id simple wrap the wood in some sort of black sheeting to give it the same effect.
Thanks bud, i've got a joiner on the case as I really want an 'oak' style finish to go with the rest of my oak furniture land stuff. Subbed will be keeping an eye on this ;) gl and hf bud.
Metal doesn't so much stay cold as conduct heat well. Wood would feel colder than metal if it were running hot because the wood doesn't conduct the heat. Metal can help radiate or convect the heat away though - hence heatsinks. Mainly you'd use it for the style aspect but also, you can drill and tap a hole in metal and then directly put a pc style machine screw into it...although, now I put it like that, wood is rather infamous for taking er, wood screws without having to tap the hole.
Looking at the design. Apart from complaining that you could fit more rads in there and hence aren't trying hard enough ;) Have you thought about having the entire floor, back panel and front slide out? If the sides have rads mounted, unless you want to have those slide out - which is awkward in terms of then supporting the top - you'd have to mount the rads on the bottom but have them line up with the sides so they slide with the bottom but exhaust out the holes in the sides.
Just thinking that once you've got a water loop connected up, unless you're planning top access as well, the removable panels aren't going to give you enough access to get to stuff without ripping the water loop free unless you leave enough slack in the hoses to look bad.
Access from the top is good too....unless you're like me and have your desk cluttered in all the crap you should have neatly filed away! ...and monitors, although you could mount them on an arm.
Yeh I see your thinking, alittle like the Lian li version, their desk version slides out the front for accessibility, I did however envisage the top glass piece simply being detachable, alittle hard for me to show it in the design but alittle like a car the bonnet will open allowing me to tinker with the top side or access the underside via the removable panels. I'm trying to Make it as accessible as possible but with the least amount of effort required from the smithy.
Regarding the rads, as it isn't correctly measured up yet it may look like there is a lot of room however I may find that I have less room when ive worked out all the correct measurements. Looking at the Red harbinger desk they could only fit 360mm down the sides and that was my thinking thus far.
This of course is going to take time, my biggest task is making this desk detachable and getting all the measurements exact which ive never been the best at lol. I'll get there, the company willing to make it seem positive which is a bonus
