Provided it doesn't leak, I'm sure its great.
£800? What car is it!
I guess the first thing i'd be looking for is the difference in size...
Surely that's all that matters really with them?
The ability to adequately cool the engine is quite high on the list of priorities for a radiator...
Well yes, but surely if it's the right size then cooling is going to be fine, just as Firestar said, pump is important.
Fair enough. I just assumed they are all the same bar shape/size..![]()
I need a new rad for the Manta, the cooling fins are mostly gone and the actual rad itself is beginning to leak when hot (a pinhole, but it's enough)
