- 7 Jan 2009
Hey guys,
I have the Hannspree (HSG1164)...now i bought this second hand,however it does not have the original rom installed.
Heres the rom it has now-
I want to know if there's a way to update the rom on this tablet,to a better one that's currently on it,because this one has a lot of issues.
Play Store wont always load properly..all i get is (Loading) though sometimes it does load.
Also when i rotate the device vertical the screen does not rotate either like it should.
Another issue is "Twitch" app,Says my device isnt supported..which i cant believe because it has a nVidia Tegra II T20 1Ghz GPU which plays Youtube HD no problems.
I think the custom rom it currently has,must have been a early release version or something with a lot of problems.
Appreciate any help a lot,Thanks in advance guys.
Android Version 3.0.1
Kernel Version 2.6.32.46-cyanogenmod
Build Number - 10.1
). Seems like an unreliable device, and probably why the original owner flashed Cyanogenmod onto it (Although it's an old version).
