Hey, I just wondered how you would go about doing this, what type of spray you would use etc. (All for the internal of the case)
I am looking at getting the Lian-Li PC-A7010B Super Full Tower Case.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-146-LL&groupid=701&catid=7&subcat=187
However the case is so large that once the components are in it will kind of ruin the look have a black case with all the water-cooling set up against a shiny tacky silver aluminium back.
Now the case pretty much comes apart in every direction..
The top comes off, the sides come off, the internals come off ect ect.
So there is no worry about getting paint on the wrong bits.
What I really need help with is what sort of spray paint to use...
Obviously I need something that is non flammable/heat resistant, and sticks to metal very well.
It is either do it myself or pay a company 70 quid to power coat the inside which I think is a stupid amount of money so i would rather do it myself.
Does anyone know which sort of paint to use? Thanks.
I should be alright with a spray can because I used to do a lot of like airfix modles when I was younger and that was when i was like 13 lol and they still look awsome better then some pro ones
