Is is possible to fit a custom loop in the Corsair Air 240. Cpu and Gpu waterblocks with a 240 and possible 120 rad. Looking at making a more compact build.
You can fit both a 120 and a 240 into an air 240, it's not easy though, especially if you go custom loop. I've seen people putting the 120 in the 'drive and psu' section of the case where you can add another fan.
If you went mitx you can actually fit 2x 240's in to the case although I'm not sure where you'd fit the res although I have seen some attach it on the rear 80mm fan area.
