- 27 Feb 2006
- Normanton
Ive decided to buy the parts seperate for my new water cooling setup rarther then going for the swiftech apex+ kit partly so I can buy bits when I have the money and as I would need to get a new gpu block anyway for the 8800gts and ive gone for a diff rad supposadly better? any opinions
Is there everything below that I will need to connect it all up ready to use apart from the water obviously didn't know how many hose clips i would need if any also not sure on best tubing size if anyone can tell me or if theres anything that ive missed or a better solution thanks budjet is around £200
Cheers
Cheers
