Custom watercool case part name
22 Jun 2010
Hello.
Am looking for a custom part for watercooling that ive seen in some builds. I dont have any pic now available to show you which part it is and i dont know its name.
Its like a plate in different sizes or shapes, and the tube screws on one spot at the plate, and it comes out from another spot. Its usually transparent and the liquid is visible form within this plate.
Any idea what is this called or you know any build that has this to post an image please?
Thank you for your time
I cant paint it or something. There is no standard shape. Its a custome shape. Its only for looks. It doesnt cool anything. Ive seen it on some builds but now i cant find any pictures with builds that have it.
its like the parts that GiraffePencils posted :1 x EK Water Blocks EK-FB KIT SR-X - Nickel £109.98
1 x EK Water Blocks EK-FB KIT ASUS R4BE - Nickel £95.99
A plate like this, with tubes inside them. And they added lights here and there, with multiple colors of liquids on each tube etc.
Ummm......I really can't think.
People don't usually have something that doesn't cool, unless it's the res.
You can add lights to a lot if not most EK plexi blocks, such as the ones I posted.
Without A picture we really can't help much
Yes its something like that. Where there is white liquid inside. But its not with cooling plates. Ive seen a case with acrylic tubes, and each tube had different color. And all the tubes ended up on one of these plates on the bottom of the case and u could see a place with many colored lines. Thats the one that made a really good impression on me and i was wondering what a part like this is called or how can yo order anything like that or make one
Sounds like a dual loop system with a custom acrylic mid/baseplate using bulkhead fittings or something. Or maybe just a custom reservoir.
You'd have to design it and get it custom made by someone who does custom mill work, I know E22 can do this, I hope this isn't again the rules if it is I'll edit it!
