- 11 Dec 2005
- Cheshire
We have updated and upgraded our range of watercooled systems to the latest Ivybridge CPUs and Intel Z77 motherboards. With high overclocks, great cooling capacity and the unique touch of custom watercooling, these system really are unique!
OcUK Tech Lab - "Titan 8400i Barracuda" Intel 4.60GHz Quad Core Ivybridge System @ £1080.28 inc VAT
The "Titan 8400i Barracuda" designed and engineered by the OcUK Tech Labs team from the ground up. Featuring an Intel Core i5 3770K 3.40GHz processor overclocked and guaranteed to a blistering 4.60GHz. With a full custom watercooling loop pre-installed the "Titan 8400i Barracuda" features quiet operation with ultra low temperatures allowing the processor to be overclocked to the highest standard. Harness the power of the GeForce GTX 560Ti 2GB with glittering DX11 graphics, select SLI option to double your firepower.
Why Should You Buy This System?
- The 4.60GHz overclock ensures lightning fast processing speeds
- Custom Watercooling for ultimate performance
- Featuring DX11 cinematic graphics
- 8 Hours stressed tested and quality controlled
- Precision built and cabled by Overclockers UK expert technicians
- All systems with an operating system selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012
System Specification
- Case: Cooler Master CM 690 II Windowed Gaming Case
- Power Supply: OCZ ZS 750W PSU
- CPU: Intel Core i5 3570K 3.40GHz @ 4.60GHz Ivybridge CPU
- Motherboard: Intel Z77 Chipset GEN3 (Socket 1155) DDR3 Motherboard
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 500GB HDD
- Graphics Card: Nvidia GeForce GTX 560Ti 2048MB GDDR5 w/ SLI option
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Watercooling Specification
- Radiator: EK-CoolStream RAD XT 240
- Pump: EK-DCP 2.2 Pump
- Reservoir: EK-Reservoir Combo DCP 2.2
- CPU Block: EK-Supreme LT - UNI CPU Waterblock
- Fittings: x6 EK-PSC Fitting 10mm - Nickel
- Tubing: x2 Masterkleer Tubing - 1m (Total 2 metres)
- Fans: Yate Loon D12SH (2200rpm) or Yate Loon D12SM 120mm Fan
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
The "Titan 8400i Barracuda" provides ultimate performance, cooling and stylish looks in one awesome package. If you like to game with more power, the "Titan 8400i Barracuda" is for you.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £1080.28 inc VAT.
ORDER NOW
OcUK Tech Lab - "Titan 8450i Frostbite" Intel Core i5 4.60GHz Quad Core Ivybridge System @ £939.97 inc VAT
The "Titan Frostbite" designed and engineered by the OcUK Tech Labs team from the ground up. Featuring an Intel Core i5 3570K 3.40GHz processor overclocked and guaranteed to a blistering 4.60GHz. With a full custom watercooling loop pre-installed the "Titan Frostbite" features quiet operation with ultra low temperatures allowing the processor to be overclocked to the highest standard. Harness the power of a multitude of graphics choice all complete with glittering DX11 graphics, providing a seamless computing experience.
Why You Should Buy This System
- True DX11 gaming performance available from a choice of compatible graphics cards
- SATA 6GB/s and Intel Ethernet for next gen computing
- Case: Corsair Carbide 500R - White
- Power Supply: PC Power & Cooling Silencer MK III 600w PSU - White
- Motherboard: Intel Z77 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Custom Watercooling Loop
- Hard Drive: 1TB HDD
- Graphics Card: Choice of the latest DX11 Graphics cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
Service Package
Ultimate performance for the ultimate gamer. Custom watercooling keeps you cool in the heat of the moment and dyanamic white & black styling makes you stand out in the crowd.
Only £939.97 inc VAT.
ORDER NOW
OcUK Tech Lab - "Ultima 9575i TUNDRA" Intel i7 4.60GHz Quad Core System @ £1599.97 inc VAT
The "Ultima 9575i TUNDRA" designed and engineered by the OcUK Tech Labs team from the ground up. Featuring an Intel Core i7 3770K 3.50GHz processor overclocked and guaranteed to a blistering 4.60GHz. With a full custom watercooling loop pre-installed the "Ultima 9575i TUNDRA" features quiet operation with ultra low temperatures allowing the processer to be overclocked to the highest standard.
*FREE: 8GB OcUK Premium USB Drive*
- Case: Corsair 600T - White
- CPU: Intel Core i7 3770K 3.50GHz @ 4.60GHz Ivybridge
- Hard Drive: 2TB HDD
Service Package
Only £1599.97 inc VAT.
ORDER NOW
OcUK Tech Lab - "Ultima 9600i Kraken" Intel 4.60GHz Quad Core Ivybridge System @ £1794.97 inc VAT
The "Ultima Kraken" designed and engineered by the OcUK Tech Labs team from the ground up. Featuring an Intel Core i7 3770K 3.50GHz processor overclocked and guaranteed to a blistering 4.60GHz. With a full custom watercooling loop pre-installed the "Ultima Kraken" features quiet operation with ultra low temperatures allowing the processer to be overclocked to the highest standard. Harness the power of the GeForce GTX 680 2GB with glittering DX11 graphics.
- Case: Cooler Master HAF X Gaming Case
- Power Supply: OCZ ZS 850W PSU
- Motherboard: Intel Z77 Chipset (Socket 1155) DDR3 Motherboard
- Graphics Card: Watercooled Nvidia GeForce GTX 680 2048MB GDDR5
- Radiator: XSPC EX360 Radiator
- Pump: Alpahcool Laing D5 Vario w/Alphacool HF D5 Top - Clear Plexi
- Reservoir: XSPC 5.25" Single Bay Reservoir - Multi Fascia
- CPU Block: EK Supreme HF - Nickel Plexi
- Fittings: x10 OcUK Fatboy 7/16" Barbs - Nickel
- Tubing: x2 Masterkleer Tubing - 1m (Total 3 metres)
- Fans: Scythe Gentle Typhoon 1850rpm 120mm Fan
Service Package
The "Ultima Kraken" provides ultimate performance, cooling and stylish looks in one awesome package. If you like to game with more power, the "Ultima Kraken" is for you.
Only £1794.97 inc VAT.
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
