Hi All,
I have *removed* is on another website (hope linking this is ok)? No it isn't - maybe check first - Thanks Armageus
I was wondering if there are any companies out there that do this kind of thing or weather its all custom made work by a developer?
Doing some googling and i cant really find the thing im after.
I like the way you can select different options and its build the fitting in front of your eyes giving you an idea on the finished look.
Any pointers or if anyone can even do this please message me.
Thanks
Thanks
