I recently fitted a 120mm case fan to the rear of the case for the exhaust.
It came with both 3 pin and 4 pin plugs, so you have the option of plugging it into the PSU or into the motherboard for monitoring.
I always intended to connect it to the 3 pin port, and the 4 pin molex was getting in the way when I was doing some re-jiggling inside my case, and in frustration I cut it off with a pair of scissors, not thinking it'd do any harm.
Now though I am wondering if there is anything else I need to do with the cut parts of cable still connected to the fan?? Is what I did safe to now leave and forget about, or do I need to do more??
Thanks for any advice
