cut out each section
19 Dec 2010
Leicestershire
How do you cut out each section and save it so i have 9 images then i print each one on to A4 and make a poster
Just need Help cutting it out THANKS
This is the first time using Adobe Illustrator CS6
Sorry images no longer available
i was trying Adobe Illustrator CS6 free trial but won't be getting that too expensive
but i have got Corel Paint Shop Pro Photo x2
or is there any better ones I could uses
Crop it to the bit you want which is in 9 a4 sheets of dimensions (63*89.1 cm or thereabouts). Control alt c and crop to 21*29.7cm in the top left corner, then print. Then ctrl alt c and crop 21*29.7 cm top centre and print
Repeat this around all 9 sections - top left, top middle, top right, middle left, centre, middlr right, bottom left, bottom centre and bottom right.
Make sure you print all at full page assuming your printer can do that.
There's probably a way of automating but professional software tends to assume that if you're going to print large then you're going to have a large format printer.
