Cut through hedge trimmer cable, how to repair?
18 Oct 2002
I noticed my Bosch hedge trimmer stopped working yesterday, I cut clean through the cable which was a bit daft. I have found a replacement cable for £34 but I don't think it cost this much in the first place.
Is it possible for me to repair it? Do I repair the cable at the join or take it apart, strip the good part of the cable and reconnect it internally?
pic host
worked for me. Less than a fiver from eBay.
They should include a few with every trimmer sold ;)
Hope that you have a RDC fitted.
How far along did you cut it? Last one I repaired, I just opened it up, and re-terminated the cable at the cut end, just ended up with a shorter cable.
Replacement cable for a hedge trimmer should not be £34, unless it's a direct replacement from the manufacturer, just looking for something like lawnmower mains cable on ebay has brought up 15m length of cable for £10, which would do the same job.
Peel back the insulation on the 4 ends, join the correct ends by wrapping the wire, then masking tape on each pair then more masking tape.
I repaired my hedge trimmer cable with a piece of chock block covered in about a meter of gaffer tape over a decade ago and it is still running perfectly.
+1
Done this at least twice :D :rolleyes:
This is a great solution if it's cut close to the trimmer, though you should be very careful to fit the female plug to the live side!
What it does allow you to have as well is a long extension for your hover mower etc, 'cos you must have cut through that one as well..?! :D
Just be aware of the total load supported by the cable if using it like that and buy an RCD when using mains powered tools...
image hosting adult
I take it your joking but you should not really post "jokes" like this as people are stupid enough to do it.
If it was a joke it would be in the realms of pooping on the cable and letting it dry.
The OP asked for cheap quick fix..... and its been working fine (in three places) on my hedge-cutter for 8 years.
Sometimes i even put a RCD at the socket if i remember.
Open up the Unit. Find where the wires connect, unsolder old wires. Buy new length cable from B&Q, solder onto unit.
Fixed.
I did this with my strimmer, and i made the cable 10m longer too!
Is there really any need for these anymore if you have modern wiring in your house that already includes an RCD?
Thanks for the suggestion. The cable is pretty long but I cut it around 50cm from the appliance end rather than the plug end.
I'm going to try and open it up and reconnect it, otherwise I like those connectors posted above to join the cable together. Is there any reason why I shouldn't use the same cable given how much length remains?
I know what you mean. My Son in law cut through his cable recently whilst using his trimmers and got quite a lengthy electric shock. He has a modern type consumer unit fitted, which could suggest that something is faulty and it needs to be checked out.
Not every home has got those types of electric units fitted and even though we do I still out of habit use a RCD type plug when using certain mains powered tools.
I don't know if they would prevent a ring tripping out though by only tripping the RCD.?
Thought that it was worth mentioning though.
No reason at all provided your happy it is still long enough and it is in good overall condition.
It is essential to hit the test buttons periodically on the RCD's they work much better second time round but nobody tells you this!
If you use a plugin RCD on the mains socket which is also RCD protected there is no way of knowing which will trip first so if it goes it could be either not that this is a big deal.
The extension lead I use in the Garden just happens to have a RCD in it so I'm double protected anyway.
