- 30 Jul 2006
Can anyone suggest a reliable way of cutting holes for a 120mm fan (? 117mm hole ?) and a 140mm fan (? 127mm hole ?) in a mild steel case please?
I have looked at hole-saws and they are outrageously expensive and just about as easy to find as hen's teeth. I am not confident that I can make a decent enough job with a Dremel.
Thanks
Thanks
