Hi all,
I got a thread on here regarding a bluetooth ceiling speaker, I went in the loft to take a look and by a rough calculation that middle point of the 4 spot lights falls right on top of a joist. just my bleeding luck
i will recheck from below (I will mark the centre point and then use a drill bit to send it upwards)
but I reckon the speaker will require me to cut around 220mm of the joist out.
The joist is very long basically runs the entire length of the house I believe probably been there over 100 years! I will be cutting a relatively small section out then using a jab saw in a circular fashion from below to remove the plaster board so that speaker fits.
Any suggestions on how safe this is and whether, I will need to use cleats or something to secure the joists before hand? Videos tips/hints and method of work in order would be most helpful kind of worried about this project.
