shimy182 said:think they are called "orbital sander". you can get them solid blades, these can cut through a lot of things.
Jonny69 said:I'd go through with an angle grinder with a 1mm cutting disc as it will make a nice neat cut. There are one or two tubes inside that you might struggle to get to (depending on the silencer) as they will probably be deeper in the silencer than the cutting disc can reach.
Another option is if you have access to a bandsaw you could lift the guard high and go right through in one go. Be bloody careful though![]()
gib786 said:... all i want to do is cut the backbox in half, and hollow the inside out, then reattach the bit ive cut off but add some kind of hinge so it can be opened and closed ...
A jigsaw?[huzeeee] said:if not one of those oscilating hacksaws?
bitslice said:are we smuggling cocaine ?
HM Customs are wise to the old "saw an exhaust in half and add a hinge" trick y'know...
