cutting crystal links
16 Oct 2010
Edinburgh
Hi guys
I thinking about tubing my rig with crystal link but Im wondering how easy it is to cut?
Has anybody cut this stuff yet?
I defiantly think most top end machines within the next wee while will be kitted out with this looks amazing when done right
Grab a pair of PVC pipe cutters, make sure they are the roller type not the shears and it should be easy enough getting a nice clean cut on them :)
btw I messaged CS today again about your other Lightning, just waiting for a reply ;)
Cheers paul :-)
Do you have any plans to use crystal link?
I diced with the idea but the cost for what it is put me off, figured if I was going that route I would be as well going all out with stainless pipe work. Decided on Monsoons now, more 90's means I just get to use more lightports :D
Can you buy large lengths of the crystal link tubing? as I could use it for keeping the flow paths clean along the mid plate area.
I think you can buy crystal tube the same size but not bitspower branded in decent lengths
I may have a google later and see what I can find.
