Hey, I've just borked my laptop with a glass of orange juice, so I'm currently 50 miles away from my PC with no transport to go get it and an Eee PC to finish my uni coursework and revision on.
My Eee happens to be a 12GB SSD version (4+8) and my C drive is just about full.
Essentially windows takes up most of it, along with the JDK (can't remove this). I've moved just about everything (firefox, 7zip etc) over to my D drive, but it's not helped too much... I've done the standard uninstall things, remove windows components, delete tmep files.... Other than those, what sort of things can I safely delete? Any folders under windows other than the temp stuff? Any language files hidden away I don't need?
Any other likely targets? Application data that will rebuild when I next use the program etc?
C:\Windows\Help seems a likely suspect? 40mb or so I can smite from there. Any problems with this?
Edit: Okay, it seems to be alive again after that impromptu watercooling session - however I'd still like to cut down my eee XP install as those "You are running out of disk space" warnings are getting irritating.
You can get away with 2GB RAM and pagefile disabled with XP if you don't do anything too demanding on it. But you might be able to reduce it a bit, unless it's already had to increase its size then try cutting it down to a 1:1 ratio with your RAM, or more if you're feeling adventurous.
