Cutting holes in case (suggestions?)
8 Jan 2003
Sheffield, UK
Hi Guys,
I'm planning on cutting some circular holes in my mobo tray on my Antec 900 so that I can hide away much of the cable clutter.
I'm planning on using some hole saw bits to drill the necessary holes. But afterwards I'd like to put some kind of rubber grommet inside the hole to protect cables from getting damaged.
I need some kind of rubber tape or a grommet that can be cut to size for this job.. Any ideas where I can get such a product?
Can't link directly as they're a competitor, but google 'blowhole trim' and you should find it. Quite a few car accessory places sell it, as said above.
perfect. Thanks guys! That blowhole trim stuff looks exactly what I need.
I wonder why OcUK aren't stocking something like this?
