Right, need to cut a hole in the side of my case for a 120mm intake fan. Had a look for holesaws but the cheapish kits only have 102 and 127mm sizes (4 & 5 inch) and, whilst you can get a 121mm one individually, they're £20 and that's without the arbor.
Don't really want to be spending £25-£30 just to cut one damn hole in the case, is there any other way I can do it without it looking completely crap?
