- 23 Sep 2008
Any advice on what tools to use and how to do it? circular or square holes?
Im looking at adding a Fan on the floor of the case as an intake and maybe one on the side as another intake. Planning to upgrade all my Case fans to Sharkoon Silent eagle 2000, so am also looking for a Fan contoller that can manage at least 4 of these and run them at full speed if needed, fir in a 3.5inch bay. any ideas?
Im also guessing im gonna need some fan gards for the case? Or just make some screw holes and then drill out some venting?
should I use internal or external filters?
And finally, ive seen a panel that come with a fan included for the eclipse, though the OCUK piccy shows it as silver? I thoiught it should be black?
