Yup, done it frequently.n3crius said:The width on the blinds go over the width of the window a bit. Anyone here cut the width of such blinds? Looks like the metal bit at the top, and all the blinds will need cutting to the same measurement, probably with a saw?
Shackley said:Yup, done it frequently.
Start with a straight edge and Stanley knife for the (unrolled) blind followed by a hacksaw for the metal rod and the plastic or wooden straightener rod at the bottom.
Peel back the blind an inch or two from the rod before cutting it with the hacksaw and then stick it back in place - to avoid making a mess of the blind at the top.
Remember - measure twice - cut once! You can't stick it back together again![]()
Houston - we may have a problem.n3crius said:Excellent mate. So, hacksaw it is. That'll do the top metal bit no problem eh?
These are venetians from Ikea. I'm guessing for the length I want to take off altogether, I take half from both sides - sound sensible?
Off to buy a drill anyway so I can grab a saw at the same time.
Shackley said:Houston - we may have a problem.
Sorry, I thought you were talking about Ikea roller blinds - I have never cut the Venetian blinds Are the slats made of wood, metal or plastic?
If wood, a fine toothed hacksaw would probably work - but would take some time.
If metal or plastic, you would probably want some sort of scissors - I have a vague feeling that Ikea have ones that are supposed to work - they are like tin snips; I definitely wouldn't use a hacksaw on them.
Also remember that with Venetian blinds, you will have to cut the same amount off both sides - with a roller blind, you only need to cut away one side.
Good luck!
It's OK, time to emigrate anyhowmp3kla said:Think he's already gone for it. You better write an apology.![]()
TheMightyTen said:Ikea sell a venetian blind cutterUncanny really it's like they already knew.
