If you are cutting wires off that you need then no
If you cutting wires that you don't need E.G Fdd floppy power, then yes. It just wont work the floppy drive
Remember and make it neat and tidy, put a rubber cap around the end or something. Cut about 2-3cm from the powersupply then wrap it in something what isnt conductive or you will get a shock next time you touch your case
Insulation tape covered by heat shrink would be the best looking and safest way.
Whatever, just make sure you get some tightly wrapped insulation tape around the bare ends.
