- 29 Sep 2010
Hi guys, i'm thinking this would be okay, I have loads of clutter behind my case due to unused adapters etc.
For example, 4 pin molex to about 4 sata cables which I really don't need, so I use 2 and then the 2 are just clogging up the space behind my case and I want it as neat as possible.
Can I just clip off the end parts which wont be used with wire cutters and tape over the cable with insulation tape and leave it? I'd imagine I can just wanting some clarification, my psu cables are stupid and would make it a lot tidier and clutter free if I ever want to change the layout or something.
Would just make it a much more comfortable fit.
